It is currently Sat Jul 19, 2025 5:50 am
 Post subject: wood dies/stains
PostPosted: Sun Oct 13, 2013 6:24 pm
First name: Hugo
Last Name: Pereira
City: Boliqueime
State: Boliqueime
Zip/Postal Code: 8100-085
Country: Portugal
Hello everyone, lucky to have found this forum. I´m from Portugal started building about a year ago. So far only finished one. A very short scale bass (25'), anda now going for may second build anda a complete cheap stratocaster makeover.
Ok so the question, i´ve been playing on scraap woods (beech and oak) and i tried two aproches dry and wet wood. I allways end up evem after sanding with black spots at the end grain. so if doing a full body and not just the top i will end with the sides being very awckawerd looking, almost loking as if painted on some spots and stained on others.
Is there any method, trick anything to avoid this??
Thank for any help
PS does anyone knows the body size for a 3/4 acoustic guitar? planning on making one for my daughter till xmas.
The sharpest the tool, the fastest it will find its way to my hands :p
https://www.facebook.com/capricornbasses?fref=ts
 Post subject: Re: wood dies/stains
PostPosted: Sun Oct 13, 2013 10:06 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Doug
PostPosted: Mon Oct 14, 2013 4:39 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Your test panels should be the same species as your body. Endgrain will always take stain darker than face grain. Wood conditioner may help, but applying it to only the endgrain will be almost impossible and if applied to the entire surface may lead to the same type difference in color with the overall tone being lighter and more even.
Brian
PostPosted: Mon Oct 14, 2013 5:20 pm
First name: Hugo
Last Name: Pereira
City: Boliqueime
State: Boliqueime
Country: Portugal
Thank just did may first sunburst findh with dies today. Didn't came out as perfect as i wanted but still looking good. As for the sides i will die them tomorrow until i get a even color or at least as close as possible all aroun.
Thank you also for the chart will be of use.
PostPosted: Tue Oct 15, 2013 6:12 pm
First name: D
Last Name: S
I've used transtint on bare wood as well as tinting clear lacquer.
Figured Maple really pops with dye on bare wood, not as much with tinted lacquer.
My experience tinting lacquer with transtint is that the color can quickly change and fade with exposure to indirect sunlight.
I have not had the fading problem with dye on bare wood.
Just my experience for what it's worth.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Oct 18, 2013 9:39 am
First name: Eric
Last Name: Reams
City: Hudson
State: FL
Zip/Postal Code: 34667
I've had luck using RIT Dye on Maple and Poplar. End grain, like mentioned above, will take more stain initially, hence the darkness, but you could always darken the back with more stain to match the edges at least.
PostPosted: Mon Oct 21, 2013 2:13 pm
First name: Hugo
Last Name: Pereira
City: Boliqueime
State: Boliqueime
Country: Portugal
No luck on the sides, After a lot of thinkering i,m going to paint the sides with black no gloss paint. After varnishing i think it will be at least nicer than now.
